Indicator heat engine water
zdebat
Post by zdebat »
Hello, how reliable indicator of heat engine water?
I changed the control panel, and now I see that it shows the temperature differs from the previous control panel.
Do you have any suggestions?
thanks
florian
Re: Indicator heat engine water
Post by florian »
your problem is the engine temperature sensor which is not compatible with the electrical characteristics of the control panel.
Yo have to put a compatible sensor .
zdebat
Post by zdebat »
I will check. Thanks.
zdebat
Post by zdebat »
Sensor is old but original. Control panel indikator is old from original aro control panel.
Maxim
Post by Maxim »
May be problems with sensor. This is can checking with help variable resistor. I have table C'-R for sensor.
Analogues for "native" temperature sensor:
VERNET ___________ B 2506 (france)
Fae ______________ 31020 (spain)
Beru _____________ 0 824 121 091 (germany)
Beru _____________ ST044 (germany)
Commercial ignition _ XTT1 (germany)
Facet ____________ 7.3008 (italy)
zdebat
Post by zdebat »
I put the new sensor, but I have the same problem. Now pointer jumps occasionally until light poorly lit. Is the problem in the contact on the control panel?
