Hello everyone,
I'm looking for a rear differential crown & pinion gear set. Crown 41 tooth & pinion 9 tooth.
It's for a 1984 ARO 10.1 1.3 litre petrol 4 speed 4x4.
I live in Australia and have absolutely no ARO parts dealers here so looking for your help. Please let me know as soon as you can if you have any.
The set in the vehicle look like the ones in the link below but the teeth go the opposite direction on mine.
http://www.aro-10.net/en/transmission-a ... iesel.html
Crown & pinion gear set for rear differential
hillhoon
- Nou venit
Re: Crown & pinion gear set for rear differential
wich rear axle do you have? rigid one? or with independent arms?
hillhoon
- Nou venit
I have the rigid one. Solid axle.
in watt condition you need the parts, used ones, or new?, the transport may be a problem, it's far away. you wil pay a lot for shiping, we wil help you but, tel uss ,how you afford the costs.
use other linck site to show us the parts, the aro-10 net, is restricted for Romanian users ,
olsow we have problems with the new spear parts, becouse they are made with scrap material(replics of the original), end we buy used ones in good condition. the price is haf but they last.
hillhoon
- Nou venit
a good second hand gear set or new set if possible.
I thought the postage wouldn't be too cheap but can't get any here.
I saw the gear set on the aro-10.net but they are for a diesel & would turn the opposite direction.
The postage cost compared to a complete diff modification is a lot cheaper so long as its a decent set of gears.
hillhoon
- Nou venit
Here are the gears out of my diff
hillhoon
- Nou venit
I really need a rear differential gear set if anyone can help.
