Brake Pads
- D@nARO
Brake Pads
Are the brake pads on an Aro 10.4 the same as anyother vehicle around? Or do i have to order them from abroad. since malta doesn'tt have any Aro parts
Re: Brake Pads
if you have normal front disc's (full) dey ar the same with R12 (renault 12)
just in the front.
the rear pads ar just for aro 10 if you have drums
you chan adapt with some cutting...the pads from dacia 1307 , but again , you can't find them.. there
just in the front.
- Maxim
Re: Brake Pads
Hi D@n!
What type of the front brakes on Your ARO (disc or drums)?
What the internal diameter of rear drums?
I are know some cross-numbers, but needed more clearly to specify of the details size.
Can You to give photos? May even to my e-mail.
- D@nARO
Re: Brake Pads
Thanks for the replies guys.. I will take some photos as soon as i can and post them. Thanks again
- Ionut
Re: Brake Pads
Hi fellow,
You also can use pads from Fiat Uno 55 , 1.1L engine, or at least this is the car I had and I used romanian pads for it. So the fiat ones should fit under your calipers too.
I had one from 1984 and another one from 1991 and they've got the same brake system.
