rainwater under cabin
zdebat
Post by zdebat »
Hello! Does anyone know where the rain enters the Aro? After a long rain I have water under the pedal in the cabin. I can not disclose where leak.
tudop
Re: rainwater under cabin
Post by tudop »
Water can enter at the lower side of the windshield, leaking behind the rubber seal of the windshield... If the rubber seal is still in good condition and has not hardened, you may remove it and seat it back properly... you may also find rust behind the seal, and it'll be recomendend to clean it up and paint that area (cleaned, primed, etc)
L.E>  You may post some pictures with details of the problem, and the areas that I described  *-:)
nÉ
Post by alex »
or,
it could easily get in the cabin through every single hole in the bulkhead. even those fixing the side wing.or any rubber seal on the steering column andso on....
silicone on any suspect entry point should keep u trouble free for  a while.
zdebat
Post by zdebat »
Thanks, I will try according to the instructions clog all the suspicious elements.
