Hello friends,
I have not had any problems with the car until these cold days. Of course, the brakes work problems. Although the power brake cylinder replaced and put new car the first few brake blocks with brakes. After that, everything is normal. All other vital brake parts are new. It even happens to the car without pressing the brake pedal brakes in place. The same problems have occurred with previous servocilindrom only to a small intensity.
Does anyone have any idea what to do?
Servo brake cylinder problem again!
- zdebat
- zdebat
- icemann
Re: Servo brake cylinder problem again!
Hi,
i have problems with the braking sistem also..
i`ve changed the main break cylinder, front and rear breaks and now i have a problem with the servo.. i need a new one, i`ll start searching for new one tomorrow..
you can test your servo with the engine on. When you press the brake pedal if the sound changes or you hear a noise like air leaking it means that the servo doesn`t hold vacum..
can you tell me the model name or car from which it came from..
best of luck
best of luck
