İs ARO 10.4 strong enough?
styleronurhan
Post by styleronurhan »
i bought my ARo 10.4 1 month ago (1989 model,1397 dacia engine,gasoline,4+1,part time 4wd)
problems
1.brakes........solved
2.rear axle right side broken.....not solved
Why axle broke?is it old?İs it weak?
can i use my jeep at lands or is it for streets?
İ heard that the front axles also broke before i buy it...What can be the problem?
TİRES?
alex4wd2001
Re: İs ARO 10.4 strong enough?
Post by alex4wd2001 »
I believe your axle had a manufacturing quality problem. :-\ Usually, they are really tough and ARO 10.4 can go off-road without any special care. I hope the forum guys around here can help you to find a rear axle for your 10.4... %%- good luck
Treaba cea mai grea e ganditu'
styleronurhan
thank you for your reply i am praying to god only for my ARO..
hello Volkan! just now i understand what part is broken to your car. "axle" is one piece, from left to right. you want the piece from the interior of thr axle. it is ok? transmision part...
styleronurhan
I want to explain again from right rear wheel a piece of metal goes to rear differential (middle of the rear wheels ..
hbogdan
Post by hbogdan »
Ok, so you're talking about the output/driving shaft.
How was it broken? Where (the axle, the connecting gears)?
Main cause is the over-torqueing of the axle (too much revs at the start), also a bad/faulty material.
styleronurhan
I must explain a detail.when i bought ARO the guy that bought gave me a circular gear part and said that this is for speed is it normal or they made modification for more torque maybe this can explain problem at my aro.Are there two choice for Aro 10.4?
hbogdan
Post by hbogdan »
A picture could be very helpful...
Bear in mind that maybe compiling a list of wanted parts will ask for a journey to Campulung Muscel in order to buy them...
hello!where do you stay in istanbul?
about one month ago I was in kadikoy-fenerbache.
styleronurhan
I live in Atakoy.my work in kadikoy fenerbahce glad to meet you ..
