.....From 27 december was crop up little vibration. To night 2 january vibration began strong and something began clank.....
.....I remove the front drive shaft (I thought, that damaged splines joint of front drive shaft). But, be found, wedge cardan cross (near the transbox). I begin the change. I am look to the cardan cross mark.....
704702 BA URB!!!
Dear Mama!!!
Cardan crosses, of the front drive shaft, never was change neither!!!
Drive shaft is made 10/1990!!!
.....On the car remained a last the URB cardan cross.....
.....Sturdy car.....
TRANSMISSION
- Maxim
- alex
Re: TRANSMISSION
hey maxim, while descending the road in 4x4 sometimes there is a sound (maybe transfer box, maybe front transmission) and the car gives the impression that it will move freely a bit. this happenns only few times duringthe descend, so a broken bit on the front crown in teh diff was excluded.
in your experience, a problem in transfer box could lead to such "slipage"???
- Maxim
Re: TRANSMISSION
Result after driving on deep snow, in the wood....
- Maxim
Re: TRANSMISSION
......And, as was found out, the right drive shaft also is damaged.......
Re: TRANSMISSION
Maxim, try UK made joints....
- Maxim
Re: TRANSMISSION
Hi Stefane!
Cross joints on the shafts is was from different producers (two - russia, one - ukraine and one - germani)
- Maxim
Re: TRANSMISSION
What the clearances is necessary to adjust, after refit a gearbox (ARO24, 4 st. )?
As it to make, with help what the parts?
Who is know?
Who is know?
