Piston rings (for UTB D127, standart size):
GOETZE_____08-207200-00
AE__________R46770 STD
KS__________800035210000
MAHLE_______007 85 N0
CABER_______RS FIV 003 , or RS FIV 014
spare parts analogues
Moderator: UMMM461
- Maxim
- Maxim
Re: spare parts analogues
continue...
Rod shell
AE_____________AEB91809STD
GLYCO__________3135RA STD
TRIONEURO______10-170/1 STD
KING___________MB 172 CP 000
Main shell
AE_____________AEM91810STD
TRIONEURO______20-170/1
KING___________CR1209 CP 000
Up rod bush
AE_____________AES96425STD
GLYCO__________66634YC SEMI
TRIONEURO______60-172/2
Rod shell
Main shell
Up rod bush
- Maxim
piston
AE____________ 21214801STD
KS_____________91476600
MAHLE__________007 85 00
piston kit assy.
KS_____________91476960
MAHLE__________007 85 90
cilinder bush
KS_____________88593190
KS_____________88699190
MAHLE__________007 WV 07
MAHLE__________007 WV 08
camshaft shell
AE_____________AEC94075STD
TRIONEURO_____40-172/3 STD
semicircular thrust
AE_____________AEW16STD
AE_____________AEW95076STD
TRIONEURO______30-170/4A
TRIONEURO______30-172/4A
piston kit assy.
cilinder bush
camshaft shell
semicircular thrust
- Maxim
valve guide
KS__________50004353 (in/out)
valve in
AE____________V91676
AE____________V91709
KS___________50004282
MAHLE________007VE30696000
TRW__________17042
valve out
AE____________V91302
AE____________V91304
AE____________V91677
AE____________V91678
KS____________50004283
MAHLE_________007VA30697000
TRW___________17043
nozzle (atomizer)
HIDROJET_______DLLA 145 S 448
DTP____________DTP 11199
valve in
TRW__________17042
valve out
TRW___________17043
nozzle (atomizer)
- Maxim
I have found some numbers for ARO brake shoes, but this is does not mean, that it is correct analogue
1. 7797112118 ARO (also original ref-num CARBODIES GBS729, Land Rover GBS729, Land Rover GBS730, Land Rover RTC3417);
Analogues for numbers 7797112118 ARO:
HP ______________________ 1456
LPR _____________________ 06100
Lucas __________________ GS6107
ROULUNDS BRAKING _________ 0401
Analogues for numbers GBS729, GBS730, RTC3417:
ALLIED SIGNAL BENDIX JURID _________ 346168B
ALLIED SIGNAL BENDIX JURID _________ 346188
ALLIED SIGNAL BENDIX JURID _________ 361349
ALLIED SIGNAL BENDIX JURID _________ 361349B
ALLIED SIGNAL BENDIX JURID _________ 361349J
ALLIED SIGNAL BENDIX JURID _________ 380294
BOSCH ________________________ 0986487459
Delphi _____________________________ LS1090
Ferodo ____________________________ FSB360
HP __________________________________ 1456
LPR ________________________________ 06100
Lucas ______________________________ GS6107
Quinton Hazell ________________________ BS580
ROULUNDS BRAKING _____________________ 0401
Valeo _______________________________ 562034
Dimensions
diam drum = 279,4 mm
width = 57 mm
thickness cover = 5 mm
brake system- Lucas
Applicability:
Aro Intreprinderea 10 1,4
Aro Intreprinderea 10 1.6
Aro Intreprinderea 10 1.6 D
Aro Intreprinderea 10 1.6 TD
Aro Intreprinderea 10 1.9 D
Aro Intreprinderea 240-244 2.5
Aro Intreprinderea 240-244 2.5 D
Aro Intreprinderea 240-244 2.5 TD
Aro Intreprinderea 240-244 2.7 D
Aro Intreprinderea 240-244 3.0
Land Rover 88/109 2.3 (LR 88 OL, LR 109 OL)
Land Rover 88/109 2.3 D (LR 88 DL, LR 109 DL)
Land Rover 88/109 3.5
Land Rover 88/109 Hardtop 2.3 (LR 88 OP, LR 109 OP)
Land Rover 88/109 Hardtop 2.3 D (LR 88 DP, LR 109 DP)
Setting place - front axle.
Please, all comments - in "Question about ARO".
Let, in this topic will be only numbers
Dimensions
width = 57 mm
brake system- Lucas
Applicability:
- Maxim
Other number - 7797112218 ARO
Analogues:
A.B.S _________________ 0554Q
A.B.S ___________________8111
BOSCH ____________ 0986487285
FERODO ________________ FSB29
FERODO ________________ FSB43
HP ______________________ 1281
Lucas _________________ GS8315
Quinton Hazell ___________ BS546
ROULUNDS BRAKING _______ 0114
Dimensions:
diam drum = 229 mm
width = 42 mm
Brake system - BENDIX
Applicability:
ARO10.1/10.4 10/79-12/93; ARO240/243/244 10/74-12/93
PEUGEOT 304, 305
RENAULT Espace I, Espace II, Fuego, 18, 20, 25, 30
TALBOT 1000, 1100, Alpine, Horizon, Rancho, Simca 1510, Solara.
Setting place - rear axle
Analogues:
Dimensions:
diam drum = 229 mm
width = 42 mm
Applicability:
PEUGEOT 304, 305
- alex
maxim, the rear ones on my truck look slightly different.
the place where the handbrake lever goes in is a slot (?) not a side cut on the rim of the metal.
maybe this version is an easier one to install.
- Maxim
Water pump for D127 (and, I think, for D111; D115, D121) :
GRAF ________________ PA031
AIRTEX ______________ 1204
BUGATTI _____________ PA0403
CAR _________________ 330600
DOLZ ________________ S139
GK __________________ 985368
HEPU ________________ P1168
OE __________________ 4639182 IVECO
OE __________________ 4655010 IVECO
OE __________________ 4655054 IVECO
OE __________________ 4679242 IVECO
OE __________________ 93191101 IVECO
OMP _________________ 196.319
RHIAG ________________ WP222
SALERI _______________ PA222
TRW _________________ FP7159
VALEO _______________ 506504
BF __________________ 20 1614 80300
BF __________________ 20 1614 80601
EMMERRE SRL _________ 907149
Meyle ________________ 233 019 1101
I have bought BF 20 1614 80601 (on photo) . All sizes are identical "native" water pump.
- Maxim
ARO 24 and UAZ is have full identical (by geometric size)
a. head rod lh/rh assy ( 593003051 / 593003050 )
b. spider (joint cross) with needle bearing ( 2402201310 )
- Maxim
Rear brake flexible pipe :
from Renault 4 (112_) 1962-1993 years, RENAULT 5 (122_) 1972-1985 years, RENAULT Rodeo 6 1970-1981 years.
analogues for it number:
Quinton Hazell BFH4478__________L=467mm
Quinton Hazell BFH4217__________L=504mm
Corteco 19018903_______________L=489mm
Corteco 19032262_______________L=447mm
Malo 8096_____________________L=500mm
TRW PHB 124__________________L=510mm
Triscan 8150 25101_____________L= ? mm
Fte 480.148J___________________L=480mm
Bosch 1 987 476 145_____________L=480mm
Fte 440.160.0J_________________L=440mm
Jurid/Bendix 17 111 3B__________L=508mm
all is having a groove 3/8' - 24UNF.
I bought, that is selected blue
- Maxim
Primary fuel pump for D127
IVECO 504090935
Another numbers for it unit:
Universal:
115 16 070
Fiat:
4609596, 4631972, 4648022, 4660069, 4667509, 4709282, 4740717, 4756678,
4757883
Ford New Holland:
4757883
Long Tractor:
TX10289
IVECO:
504090936
IVECO 504090935
Universal:
115 16 070
Fiat:
4757883
Ford New Holland:
4757883
Long Tractor:
TX10289
IVECO:
504090936
For D127 engine, primary fuel pump, you can use from VW Golf3, it's the same.
